Sorry this is long... But help will be appreciated.
Hi there. I have a AMD 2800+ Barton and today I was just fooling around trying to see if I could oc it. I had my fsb set at 166 in the bios and every time I tried setting it higher (167 or anything higher) the computer would no longer boot. It would turn on but would not do anything. I then reset the cmos by removing the batt and all was good again. Until I went online and was reading about this motherboard. Someone said to remove the dps card, which I did. I then booted the computer and went right into windows (using fsb 166). Motherboard monitor alerted me that my cpu temp was 60C and rising and I noticed my computer was quieter than usual. My cpu fan is spinning VERY slow now. It's a coolermaster, not sure which one. The fan has a manual speed control using a little knob, which now makes no difference in the speed. This makes no sense to me because this fan is not even powered through the motherboard, it dose have a sensor connected to the motherboard but the power is right from the ps. So I tried also reattaching the dps card and it makes no difference. Now that it's almost 1am I gave up on trouble shooting it and booted up my laptop to seek help. I don't even care about overclocking at this point it seems to be impossible with this board for me. All I care about now is why my fan is running dangerously slow. Thanks for the help!
