Hey guys been lingering around the scene for sometime now not really been into over/under clocking until just recently with the AMD FX9590 power sucker! (yes i know), Anyway I've had this CPU for about 3 years now and basically ran it with optimised defaults with Turbo Boost switched off as this caused system hangs, So since then its been running at 4.7ghz albeit unbeknown to me unstable which has recently been showing its instability in the recent Windows 10 creators insider releases, TBH I have been using my PC more recently which is probably why these issues are popping up.
So I've garnered the info from various threads here and there with regards to down clocking this beast as its plainly obvious my Scythe tower cooler with a push and pull fan setup just cant tame this beast at 5ghz or 4.7ghz without going into a thermo nuclear meltdown..... Anyway I seem to have found a happy stableish kind of place at 4.5ghz which runs prime small FFT for 2 hours (i got bored after this time) without killing off any workers or burning my house down but the blend test is another story well it ran for 7ish hours before worker 8 died twice over 2 days...
So snooping in the bios again and I find LLC... Which seems to fluctuate any set voltage I give to the vcore.. I will start with 1 question and reply when I can to any counter question.
How can I have the vcore stay put? So like when I set it for 1.404 it will stay at 1.404 and not venture +/- off at about 0.025v each way..
Thanks in advance for any help..
