- Nov 7, 2004
I sent off my board below because I thought it was developing coil whine and after nearly 3 weeks overclockers where I bought it from sent me a replacement, now this board is having powering up issues. It sometimes will not power up at all even thought there is power coming from the PSU as I have a memory card reader in one of my floppy drives and that shows power.
Now when it wont power up from the press of the switch I try to switch it off at the back of the PSU and I wait because 3 days ago it worked, when I switch it on the red LED in the PSU flickers on and I am greeted with the WALLPAPER thing from my board. The time/date has reset and so has some other options and I get the message along the line that basically an overclock has failed and the board has reset to stock settings.
Issue being here is only the date/time memory speed (1600mhz at 1.5v) and drive order have been reset some options remain the same. I am not sure what it could be I have copper caps where the board screws go into and I can narrow it down to 3 things.
Either
PSU is failing though it was perfectly fine until I got this replacement board.
Board if faulty
Coin battery needs replacements
Or maybe a 5th take out board bench test it again completely outside of case.
I am not happy that if the board is faulty I have to send it back again it costs £9 to send it back and really I SHOULDNT have to pay again for a faulty board. Would you say doing the above is 1st task
Either
Board if faulty
