- May 9, 2011
- Alberta, Canada
Hey all. I've been trying to troubleshoot a problem with my motherboard but I've hit a pretty solid brick wall and was hoping to get some help from the experts here.
I have a Gigabyte G1.Sniper 5 motherboard with a stock 4770K and 16GB (4x4GB) of Crucial Ballistix Tactical Tracer 1333 RAM. When I first built it, everything seemed fine. Then I decided to update the bios firmware from the factory installed one to the latest. Now it constantly goes into a boot loop whenever I try to start it with a very small chance of actually booting into Windows on the main bios (it has dual bios).
I've tried reflashing the newest bios firmware (it won't let me revert to an older version), clearing the CMOS, loading the default bios settings, all to no avail.
I should mention that as soon as I switch it to the backup bios, everything works perfectly. There is no boot loop.
Other things I've noticed, since I have the tactical tracer RAM (with LED lights), whenever I boot in the main bios, it usually does not light up the RAM indicating that there's no RAM activity. This is also accompanied by a "Pre-memory North-Bridge initialization is started" debug LED code before it resets.
Some times, it will light up the RAM, but will show a "No Console Output Devices are found" debug code and then reboot.
I'm completely stumped. Both the main bios and backup bios are the F9 (latest version) bios. All settings are completely the same between the two.
Any help would be greatly appreciated. Thanks in advance!
