- Jun 9, 2010
I know it requires a lot of patience, but between the damn little rectangle that shows up half the times I press DEL, making me reboot and try again, and the infinity of combinations of different settings, it becomes a daunting task. I mean, I've had a test installation of Windows for a week now without all my software because I want to make the definitive installation only when I got a stable 4 Ghz, which according to many, is perfectly possible with this CPU. But I keep trying and trying and nothing seems to work.
Now the latest settings I'm trying (running Prime for about 15 minutes now) is all the voltages just one step above normal. When I say one step I mean just that, I went into every voltage that could be modified and I selected one value above the normal. This seems stable, but according to CoreTemp, after about fifteen minutes the temperature was 65C, so I stopped it. Perhaps 4 Ghz is not achievable with my current cooler, the Cooler Master Hyper212, or perhaps I could try attaching another 120mm fan on the other side of it, but I don't know exactly where should I plug it, since the fan that's already attached uses the CPU Fan connector. So I could use the SYS_FAN1 connector, but how do I know that it will run at the same speed to create an even flow? I had the front fan connected to that, and it would run at 200 or 300 RPM all the time, so I had to connect it to the PWR_FAN connector to get a full speed.
Other than the voltages, what about the settings above that? Should I change the multiplier for the Northbridge Frequency, the HT Link Frequency, etc? I read that some people change the Host Clock Control, but if I change that, even at the normal of 200, this starts blinking in red: "System Voltage NOT Optimized", even if all the voltages are set to normal. So I didn't change that at all.
At least yours didn't kill itself when you had the audacity to open the DVD tray in BIOS.
