got another question to ask, the board comes with a CPB (core Performance Booster) im guessing thats whats utilizes the turbo mode on the processor? if im going to overclock the thing anyways this should be disabled correct? = I would think it would be so or the board might be trying to move the speed up and down.
Rgone for overclocking my memory (16gb ddr3 Corsair Vengeance LP) should i do it? or not worth it (9-9-9-24 1600mhz timings) if i would have know that this was going to be my final decision on this board i would have got the 1866 but oh well can get it later. = You can try anything in a test to see what might happen with the ram overclocked. Who knows how far it will go. I have seen good DDR1600 go to DDR1800 with a little extra ram voltage. And if the DDR1866 ram had 10, 10 type timings then I doubt it would have added any real performance boost.
Really what you must consider is that the 4100 is like a pimped out dual core. Given its the most expensive dual core AMD offers but its new tech, and that has to be expected. I will say the fact that the performance per unit is actually impressive when you look at them as 2,3, and 4 core chips instead of the advertised 4 6 8. Price vs performance BD is on the meh list ATM. IMO its advantages lie in future scaling.
Im sure you will still be happy with your new system. Make sure to report back so we can all learn something.
well rgone i talked to gigabyte for numerous hours and it was a defective RAID controller on the board itself that was causing my lockups and reboots. mem checked out ok, processor was running fine, could not get the RAID controller to setup correctly after numerous hours. so sending the board back in and while i was taking everything apart to get the mobo sent back in, u aint gonna believe this, moving the heatsink just a tiny bit to get it off the process i mean NO FORCE at all hardly the processor pulled right out of the motherboard. but to make sure i dont go through anymore crap again im just sending everything back and getting the phenom x4 956 with a asus motherboard. after all the issues with this billed right out of the boxed even BEFORE i ocd. i ocd it after i got everything installed and more than a few hours of runtime. hell i installed bf3 to play and nothing but texture glitches (rainbow colors) and random resets. thats when i decided to see what was wrong. so between the processor almost falling out of the board before i touched it, to the other lockups reboots. its better to start from scratch. the processor was running fine, but BF3 was running hella slow compared to my buddies build which was almost the same as mine. im not new to building machines, this was by far the most busted machine i ever tried to build. im always carefully with getting everything together. i just think it was my time to get some DOA equipment. soon as i get it sent in and get the new stuff ill let ya guys know how its going. thanks for all the advice.
and the best news is newegg is refunding me all my doe spend with no restocking fees. ty newegg!
no matter stock or OCd BF3 was nothing but a hellraiser of a ride. lock ups and resets no matter what settings i threw at it.
also windows 7 saw all my memory, i didnt bother running memtest, which was prolly a badthing on my part. but im pretty sure its not the memory going to run it in friends comp to see if anything happens. BIOS posted, windows saw all memory and speed 1600
All Gigabyte 990X/FX boards have 1 issue, no options to disable APM or control LLC in BIOS what as an effect causes voltage jumping, huge vdrop and throttling ( almost only while overclocking ). No matter if it's 990XA or FXA or any version like UD3/UD5/UD7, on all boards without special beta bios it's exactly the same ( and beta with LLC isn't public ). You can disable throttling using AOD - enable turbo core and disable it, then it's turning off ... but it's working only till you restart pc.
Since all 990X/FX boards have less or more issues, it's hard to recommend any board for FX cpu. Gigabyte would be perfect with fixed BIOS...
