- Jun 3, 2019
I recently upgraded my main PC and wanted to try my hand at overclocking with my old components. The hardware I am using is listed below:
Processor: AMD FX-6100
MoBo: Gigabyte GA-990FXA-UD3 (rev 3.0)
RAM: G.skill f3-10666cl9d-8gbrl (x2) & G.skill f3-12800cl9d-8gbrl (x2)
PSU: Thermaltake SMART 600W
GPU: Radeon 6850 (x2 crossfired)
I followed this guide to manually change my OC settings through the board's BIOS:
https://forums.tweaktown.com/gigaby...caling-charts-max-ocs-ln2-results-coming.html
I currently have the multiplier set to 20 (4.0GHz). I have disabled the core boost and turned off all the unnecessary power features. The PC boots up just fine and loads windows with no problem. I downloaded prime 95, but the application itself keeps crashing whenever I try to run a torture test. When I look at the monitoring software, the core voltage/multiplier fluctuate all over the place. The Gigabyte board I am using is not very user-friendly in the BIOs, and will not show me my Vcore voltage. Instead, I have increased the voltage by .025 incrementally until the monitoring software shows a max voltage of 1.464V whenever the multiplier hits 20. In the monitoring software, the multiplier/voltage tends to jump around. From what I have read; I am under the impression that is normal. I am not sure why I cannot run prime 95. Does anyone have any suggestions? Am I missing something??
Below are screenshots of my current BIOs settings, as well as Prime 95 crashing with the monitoring software running at that moment.
I appreciate anyone's time and effort if they are actually willing to help. I know these components are old. I get it. I'm not looking to upgrade. Please don't suggest buying new parts. This is a spare-PC. I'm looking to learn and would actually appreciate helpful replies.
