- Sep 23, 2001
- In your head (Ottawa.Canada)
I just installed my Gigabyte GA-Z87X-OC and everything is peachy keen 'cept for my memory. 2x4gb Mushkin enhanced Blackline and 2x2gb Mushkin enhanced blackline
I am unable to use my 12gigs of memory (it works, just popped it out of my old rig)
I can only post w/ either 4 gigs of ram installed in DDR1 and DDR3 or 8 gigs in the same slots.
The only way it would post was w/ the memory in the config you see below
In the slots: DDR1, DDR3
2x2gb will work in DDR1 and DDR3
2x4gb will work in DDR1 and DDR3
If I put 2x4gb in ddr1 and ddr2,it wont post.
If I put 2x4gb in ddr1 and ddr2 it wont post.
2x4 and 2x2 in DDR 4 and DDR3 = no post
Sugestions...help....
