Good day to you all, I' m a new gigabyte user with a problem, so I wanted to have a confirm.
Problem is, I' ve buyed an upgrade for my rig (mainboard Gigabyte z97 gaming Gt and cpu I7 4790k), and after mounting all pieces it keeps rebooting after some second, not even post (in fact it gives nothing at screen too), and last thing is on main onboard led it signal code "20", as in photo:
http://farm4.staticflickr.com/3857/15193134421_ea8294cc5a_b.jpg
Tried all the usual (unpluggin energy, unplugging battery, verify cpu cooler, unplug all peripherals, ecc).
In particular, on manual it doesn' t say anything about specific code 20, but all codes beginning with 2 are about Ram startup.
My actual rams are 4x4gb blocks of code F3-17000CL11D-8GBXL, inclused on memory list for this main and tested on old rig with memtest for the usual night, no problems. tested to be sure in all slots slots with one ram at time on new motherboard, still nothing, so I suspect problems on ram slots.
Already sent a ticket to gigabyte, but having readen on forum that they aren' t so fast, and before sending back the pieces to vendor I want to ask to you:
someone already faced this code and can confirm to me what mean? some other idea about what can the problem be, or solutions that I haven' t thinked about? can be maybe the cpu that is faulted?
the other pieces of my brig are the case NZXT Switch 810, the psu an Enermax Revolution 85+ 1250W, all pieces once putted old rig again works without fail.
Thanks in advance, and sorry for my bad english (I' m italian)
P.S.: As adding from reply from other forums, I' ve already tried clear cmos too, and i can add that:
- I' ve tried switching levers and used the backup bios on single bios mode, the problem remains, nothing at video but it doesn' t reboot, stay still for indefinied time.
- I read that you need f5 bios version for this main to accept this cpu and I feared that it couldn' t go even on bios, but online (this forum too if I remember well) I' ve readen that it still arrive on bios with the f2 version thi main is shipped with. Can someone please confirm this?
