As far as i know, that third pin is just to monitor RPM.
Awesome
gd point...as his sig it says its running at 1066....maybe set the ratio to 2.
That's the thing..
I can run the ram at 3.0/2:3 ratio at 1068Mhz, 5-5-5-18, but I see no increase in performance in memory benchmarks, which I've tried to explain
here, I'm not 100% it's configured correctly but surely the memory IS at that speed to have it displayed in the BIOS & CPU-Z, and to even boot up.
However if I stay at 2.0/1:1 and take my CPU to 400*8 (3.2Ghz), 800Mhz DDR at 4-4-4-15 I get stability issues, which become apprant within an hour of usage (crashing, locking up, BSOD shutting down etc), My is at vDIMM at 2.2v (coverd by warranty) and increasing the CPU voltage doesn't seem to help any as it boots at 1.3v at 2.8ghz, yet crashes eventually at 3.2Ghz at 1.425v. Even at 1.425v (about 1.380v according to CPU-Z) it still isn't 100% stable. Would increasing the northbridge and/or FSB voltage by +0.1v help me with stability? then I may be able to lower my CPU voltage a tad. I'm certain I've tried this with no success but I'll just ask.
I've tried lowering the multi (7*) and increasing the FSB too, but after about 420 Bus Speed it gets extremely unstable. The only way I could hit 1068Mhz memory was by setting the Bus Speed to something like 356Mhz and using a 3.0/2:3 ratio. It was a bit pointless but surely that shows the memory IS capable of hitting that speed, right?
Hm, here are some BIOS screenshots, as my computer is now. Which seems unstable by way Windows Vista booted up (it shows the password box before anything else, which is only does when it's unstable, atleast from what I've witnessed after a week of ****ing around)
Disabled all the stuff I don't need/use
Memory settings
Voltages
Any ideas? I am sure it's set up correctly. I get the feeling I am missing something quite obvious and that I should know.
