- May 27, 2017
Hello and thanks for taking the time to read my post people. First off here are my system specs.
- i5 6600k @ 4.4ghz
- Gigabyte z170 UD5
- Corsair LPX 3000 RAM 15-15-17-35 @ 1.35v
- Corsair Rm850i PSU @ 850w
- Evga Gtx 1070 FTW Edition with no OC other than factory.
- Corsair H100i Cooler in push/pull setup
I was wondering about voltage spikes in offset or adaptive mode on this board. I'm not sure what Gigabyte calls it but it seems adaptive to me. I set the vcore on normal and set dvid to 0.00v to get my base voltage which was 1.210v. so i then added +0.030 to give me 1.240v. Everything is stable at this voltage and i have all power saving features turned on also. i have my ring core or uncore at 4.3ghz.
When i'm stress testing with prime 95 v26.6. I noticed the voltage will be close to what i set 1.240v but then it it will spike up to 1.272v-1.284v when it gets to crunching hard and if i run Intel Burn Test it will stay at 1.284v. i do have LLC set to High and i'm wondering if this is normal when in offset or whatever Gigabyte wants to call it? i figured with LLC on High it would help minimize spikes, but maybe that is how it works in offset mode.*shrug
I also tried to bump my offset up to bring me up to 1.284v or close to it. i thought maybe it was spiking up because it wanted that extra voltage but it was still jumping from 1.284v to 1.32v give or take @ 4.4ghz. *shrug
I do like that low idle when i'm not doing anything demanding. I just got this rig not long ago and upgraded from my trusty i5 2500k rig which is now the family HTPC now. Just wondering if this is normal or something wrong with my board maybe. Also i'm running latest Bios F22 if that matters. If anyone needs any information i may have left out, let me know. Thanks!
- i5 6600k @ 4.4ghz
- Gigabyte z170 UD5
