Hey guys,
well im making my first liquid cooling system on my PC and i've some stuff that I would like to get advices from you about it.
I'll be installing this system on HAF X case with these parts :
CPU Block : XSPC Raystorm ( blue led )
Rad : Black Ice GTX 420 ( 3x 140mm noiseblocker fans )
fittings : Bitspower Premium G1/4" black sparkle high flow 3/8" (1/2" OD) Comp fitting.
Pump : Uber 655 fully modded ( D5 ) - Matte Black ( with top )
Coolant : Ice Dragon nanofluid
Res : Bitspower Dual / Single D5 Top Upgrade Kit 150 ( black POM cap )
Mounting : Alphacool Mounting for ext reservior 60mm & Bitspower 140 water tank.
IandH Silver KillCoils
Masterkleer tubing
Ok here we go !
I'll operate by this sketch :
1. I'll remove the HDD mounting because I'm using one HDD and one SSD. I'll paste the SSD on the back of the PC , about the HDD he will be in the HDD mounting that comes with the HAF X. eventually I'll put the pump + res there.
2. I'll need to cut abit for the rad ( quite big ) not a serious work to be done.
this aint hard work but I'm going on details so I wont get any serious mistakes in the future. if u got any suggestions for my new setup I'll be thanksfull.
I really need your advice & experience how to sort the tubing right without any ugly crosses.
other comments are welcome also
Thanks in adv !
Masterkleer tubing
Ok here we go !
Thanks in adv !
