- Dec 14, 2010
I've been using the Thermalright Ultra 120 Extreme (TRUE) basically forever, but recently I've began to wonder what other good heatsinks are out there for air cooling.
I guess you could say I'm a bit biased when it comes to heatsinks, as I haven't really tried many others. Tried the Zalman 9500 and 9700, but both gave consistently higher temps than a TRUE in my PC, and their stock fans are rather loud at full speed (and are not able to be swapped out for quieter fans). Also tried a Tuniq Tower 120, which was an abomination to mount, and gave worse temps (quite disappointed in that one).
So, I'm wondering what heatsinks are out there that can match or beat the performance of the TRUE without breaking the bank (sub $50 let's say).
I've heard a lot about the Prolimatech Megahalems being a good heatsink, but it's also quite expensive when bought new.
Hear of the CM Hyper 212+/212 Evo fairly often, but they seem to not score as well in most reviews as the TRUE. So, even though they are relatively cheap, they aren't the best option for replacing a TRUE.
Someone recommended the Xigmatek SD1283 Dark Knight to me a while back, and it does look kind of neat.
I've tried a Thermalright Silver Arrow SB-E Extreme, but it honestly showed no difference from my TRUE performance-wise in my test system. This was probably because the CPU's don't produce much of a heatload being Core 2 Duo's and Core 2 Quad's, so not enough heat produced to show a difference in performance. And with the stock fans it was a good deal louder for no performance gain.
