Thanks, its good to be here. Im doing an loop with ek cpu and gpu block with backplate, xspc 360 and 240 rads, ek ddc pump/res combo, ek csq compression fittings ( 7/16 by 5/8) and red tubing. (not sure what brand yet). Case is a phanteks enthoo pro and i need to figure out how im going to mount the pump/res.
Most likely "on top of" the PSU cover unless you want to hide the reservoir & pump. Loop routing becomes "interesting thou" with the Res like that
OR you could go for a Swiftech MCR-Drive 360 rad with build-in Reservoir & Pump and then you dont have to worry about where to put pump & reservoir and thus less about loop routing
http://www.swiftech.com/mcr-x20-drive-rev3.aspx
Does it matter if you mix and match radiators? Like going with the swiftech 240 and an xspc rx360?
