Have you tried 450fsb at 10?
Careful playing with GTLREF, that's one of the only ways I've heard of you can actually kill a 65nm Core 2..
Look's like your stuck at 3.2 maybe a dud chipYea I have the same problem with 9 or 10 multi with just 400fsb. So the reason the cpu won't clock that high are the temps? So, if I were to put a w/c block on the cpu, I'd, theoretically, be able to reach those high clocks?
i would say ACS on PWM's and AS5 on NB/SB. though i still would use ASC, since i have a hugh tube of it i paid $10 for like 3years ago.
No all you have to do is keep the memory in spec 800Mhz and belowYea I've tried 1:1. I dont' remember exactly why I changed to 1:1.25 but I think I read a suggestion to change it to 1:1.25. I'm also thinking it's more stable. Could you guys explain this whole FSB to ram speed ratio? I mean thought I understood it. I thought that ram just needed to be the fsb x 2. So let's say I'm running 400mhz fsb, I thought all I need was 800mhz ram(2 x 400). Also, if that thinking is correct, then why do you multiply the fsb by two? Do things change when you're using 8 gigs of ram as opposed to 2, in terms of fsb to ram speed?
while im not getting the whole picture here... if your running 4 dimms in the board then your going to need a touch more NB voltage. since it the NB is stressed more in this setup. no if your just running 2x2gig kit then no there is no difference in ocing 2gigs vs 4gigs as long as its still just 2 dimms in the board. the simpliest way i can releate the Abit dividers is like multipliers for the ram like cpu multies. 1:1/1:1.125,for instance then take the number and times 2 for DDR speed. use the second number then multipy it by the fsb. making a 1:1 ratio in line with your FSB speed, so at 400mhz your ram is at DDR2-800,now if your pumping alot of voltage to the ram like 2.1 for ddr2-800 cas5 then you can cuase errors in the ram. at 1.25x400 your ram speed would be DDR2-1000.... which your ram can do no problem since it specced for DDR2-1066 cas5. i still feel there is setting "we" are overlooking or is being left out. when i get home later i will PM you for some info.. i will say i think the biggest problem you have now is cooling. you would have better luck with a TRUE or ninja hs over that zalaman cooler. while it can handle some oced cpus, i wouldnt be using it for a oced quad core.Yea I've tried 1:1. I dont' remember exactly why I changed to 1:1.25 but I think I read a suggestion to change it to 1:1.25. I'm also thinking ithat the change to 1:1.25 made things more stable. Could you guys explain this whole FSB to ram speed ratio? I mean thought I understood it. I thought that ram just needed to be the fsb x 2. So let's say I'm running 400mhz fsb, I thought all I need was 800mhz ram(2 x 400). Also, if that thinking is correct, then why do you multiply the fsb by two? Do things change when you're using 8 gigs of ram as opposed to 2, in terms of fsb to ram speed?
3 posts saying the same thing.....I think you just have a dud chip thats all.
Well that took allot more V core than most voltage safety people on this form will not condone.I find funny you said that same thing about Klear's E7200 as well cause it couldnt hit 3.8ghz. yet i was able to help him hit that speed
Don't get me wrong i think just about anything can bee done short term, but will it fail to degradation.
Klear only did a post of him priming. He never posted that he was prime stable at 2.8 he never came back.as well with klear he didnt need more CPUV, what he needed was a touch more CPUVTT. those two functions are different are very different.
this is for that thread so drop it from here. try to help the op instead of being a echo in a cave.Klear only did a post of him priming. He never posted that he was prime stable at 2.8 he never came back.
