- Jul 20, 2005
- Chicago, IL
I've had an issue with any games causing system crashes for a really long time now. I've thought that it was a symptom of me failing to dial-in my overclock, but I'm realizing that I think it's a heat related issue. I've set my CPU/GPU to stock and the issues persist. My loop is a 2x120 rad; Swiftech CPU block; EK 290 full cover block w/ back plate, and an XSPC dual bay res/pump. When running benches like AIDA64 w/ GPU stress test, the back plate stays fairly cool. When running games, my system will typically crash after about 10-30 minutes. When I touch the back plate, it's almost too hot to keep my hand on.
My CPU and GPU temps from AIDA64 and GPU-Z are consistently mid to high 50s, so I didn't think there could possibly be a heat issue. But I can't think of what else could be causing the crashes. Is there a chance my VRMs are overheating? I got the GPU block and back plate and installed it myself, and I used heat pads and thermal compound on the VRMs. I got the card as a miner on this forum, but I don't remember it crashing like this until I put on the water block. It was over a year ago though, so my memory is fuzzy.
Any thoughts?
Any thoughts?
