- Jun 16, 2001
I know I've been gone for quite sometime but I need some help guys. I'm now up to 4days with no GPU WUs. I know someone knows the answer to this.
So I was running v7 client but it asked for an update so I decided to move back to high performance clients. Because really what is the point of running a client that isn't high performance?
SMP is chugging along just fine using FAH6.34-win32-SMP
Are there any flags I should or should not be running on my rig the phenomIIx4 945?
GPU is not getting work
this is the log
Right now up to attempt 30 for getting a wu.
thanks in advance for the info.
Code:
Arguments: -local -verbosity 9 -advmethods -smp 4
Code:
Windows XP/2003 GPU2 Console client6.23 on an ati 5870 1gb
running these flags -forcegpu ati_r800 -verbosity 9 -forceasm and set flag for big packets
this is the log
Code:
--- Opening Log file [May 9 03:56:00 UTC]
# Windows GPU Console Edition #################################################
Folding@Home Client Version 6.23
http://folding.stanford.edu
Launch directory: C:\FAHClient\GPU
Executable: C:\FAHClient\GPU\[email protected]
Arguments: -verbosity 9 -forceasm -forcegpu ati_r800
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[03:56:00] - Ask before connecting: No
[03:56:00] - User name: The_Penguin (Team 32)
[03:56:00] - User ID: 1072F15A11733D7B
[03:56:00] - Machine ID: 2
[03:56:00]
[03:56:00] Loaded queue successfully.
[03:56:00] - Preparing to get new work unit...
[03:56:00] + Attempting to get work packet
[03:56:00] - Autosending finished units... [May 9 03:56:00 UTC]
[03:56:00] - Will indicate memory of 4095 MB
[03:56:00] - Detect CPU.[03:56:00] Trying to send all finished work units
Vendor: AuthenticAMD, Family: 15, Model: 4, Stepping: 3
[03:56:00] + No unsent completed units remaining.
[03:56:00] - Autosend completed
[03:56:00] - Connecting to assignment server
[03:56:00] Connecting to http://assign-GPU.stanford.edu:8080/
[03:56:01] Posted data.
[03:56:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:56:01] + Couldn't get work instructions.
[03:56:01] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
