- Aug 20, 2002
- In a house
Ok, I've looked at AutoZone, O'Reilly Auto, Home Depot, Lowes, Radio Shack - and just about everywhere else, and I can't find SQUARE grills!
Here's the deal. I have two case fans in the front of the system, and of course, the air is expected to be pulled in through the wimpy slot at the front/bottom of the case.
so I pulled off the front of the case and using my handy dany RotoZip, routed some nice holes to let the air right on through.
Now, I did have an old 14" monitor, and monitor cases have all kinds of potential for grills - check the sides and top. But they're plastic, and kinda crappy.
I took the monitor apart and it has a swiss cheese looking grounding plate that worked well. The only problem is that after cutting out the panels at the correct size, I've got scalloped edges on these grills.
So the big question is, does anybody have a source for plain, square grills with either slots or holes?
