I just bought this kit a week ago.
and had been playing around with it a lot.
I am on R4E, so it is a x79 chip set with 3930k
first finding, is that on Primary 10-12-12-31-2
I can make it into 10-11-12-31-1 without problems.
however, anymore tuning will result in a Prime95 failure with large FFT.
secondaries.
I manage to tighten to this:
4-220-10-6-20-4-6
I cannot get the DRAM cycle time to go under 220.. which is a drag on SuperPi32M. (won't boot if below)
the rest I can't complain really. pretty good.
On Teritary. I can safely go:
0-0-0-0-3-3-1-1-5-0 without issue.
DRAM clock best at 6.
disabling enhancing training helps slightly on reset time.
NOW.
SuperPi32M time now at 7m02s which is about the same as my Corsair 2133 9-12-11-27-1 kit. in fact, the Corsair 2133 kit can be overclocked to 2400 for a 6m50s SuperPi 32M time.. (though system not too stable.. passes P95 large FFT, but will give low voltage crashes.. so I reverted 2400 back to 2133.) The Corsair Dominator GT has DRAM cycle time at 108, and I feel that is the main difference there. the other timings are fairly similar.
Now..
I am consider chaning my 2400 Trident from 2400 to 2133 for tighter timings. Anyone think that can be done? I was thinking if I can get it to go 8 on CAS that will be pretty good.. but I would like to see has anyone tried that, and learn from the experience before going further.
insights appreciated.
secondaries.
4-220-10-6-20-4-6
NOW.
Now..
