- May 8, 2003
- BC
Hey guys, I recently got a smokin deal on a used GTX 280 OC to replace my 8800 GTS that I have had for years. One thing I noticed while running this card is that it does get quite hot compared to my old card, not 100C like some people have had with their 280's, but still around 84C under load after half an hour.
I was wondering if replacing the TIM on the card would make much of a difference. I have some MX-2 and would consider picking up some MX-4 to use on it instead (might as well have the best!).
From what I have seen online, you don't want to remove the pads that make contact with the ram chips so I am only really concerned with the chip.
Has anyone done this? What kind of results have you had? It would be nice to get it below 80C so that I can turn the fan down. It was running somewhere around 75% to keep it stable at 84C and even that is too loud for me (Note: This was with the card overclocked even more to 635 core, 2302 memory and 1391 shader)
