- Mar 14, 2012
Hello all
I got an SLI question pertaining to the power connectors. Before i ask here is my system details.
CPU: i5 2500K (gotten to 4.9 @ 1.41v older s775 Thermalright ultra-90 cooler)
Mobo: Asrock Extreme4 Gen3
Ram: 16Gb G.Skill Sniper. Low Voltage 1.35v
Gfx: EVGA GTX 570 Classified (hit 980 on core @ 1.113v stock vram speed)
PSU: Antec HCG 750w 62amp max, 4 12v Rails @ 40 amp
I run it everyday at 4.0ghz cpu and stock on the gpu. No need to do serious OCin yet. Unless i get bored and do a Kamakazie Run in 3dmark.
Any way I ordered a second GTX 570 Classified(backordered, but i believe i got one coming) My question is since I have a 4 -12v Rail design on my psu would it be best/ok to hook up the 6,8 pin power to the cards in a cross(x) style configuration. As in one 8 pin from one lead goes to one card while the 6 pin from the same lead goes to the other card. the same for the other lead, 8 pin to one card 6 pin to the other card. Only reason i ask is to avoid the big loop that occurs when hooking both the 6 and 8 pin from 1 lead to one card. my psu wires are hard to bend between the 6 , 8 pin and I'd rather avoid it, plus i think it would look better like an X between them instead of a round loop from both cards.
I havent looked into it much. Asked a few friends. I'm not sure it will fit lenght wise. I'll see when the card shows up. Any help would be appreciated.
