That is an SLI test Mark, we are talking single card. The links I have seen don't show that kind of difference...oh well.
Here's a FPS test for Witcher 3:
http://www.guru3d.com/articles_pages/the_witcher_3_graphics_performance_review,5.html
W3 seems to have a huge advantage with the Maxwell cards. In other games the 780Ti gets only a few % as ED stated. Nvidia will surely be enhancing the 9 series cards and it's highly doubtful that we'll see them improving the 7 series as we move forward in time. You will most likely want the hardware level DX 12 support to really see the difference. It's hard to call right now but it seems the software level support is just so that the game will run but you won't have the big features that DX12 hardware will provide. I would not be trading down to 780Ti's as a gamer in July of 2015
http://www.pcworld.com/article/2873...nt-require-a-new-graphics-card-after-all.html
”DirectX 12 will indeed make lower-level abstraction available (but not mandatory—there will be backward-compatibility with DX11) on existing hardware. However, Tamasi explained that DirectX 12 will introduce a set of new features in addition to the lower-level abstraction, and those features will require new hardware. In his words, Microsoft “only teased” at some of those additions this week, and a “whole bunch more” are coming.”
The other one that caught my was:
"To get the full support of DX12 will users need to get a new graphics card?"
To get the "full benefits of DX12," Ybarra replied, "the answer is yes."
from
http://www.polygon.com/2015/1/22/7874793/directx-12-wont-require-a-new-graphics-card-after-all
While I agree that the newer cards will be able to take advantage of newer things, I still believe that our 700 series(and older) cards will do just fine.
GTX780Ti has more shaders and wider memory bus so it's simply faster but nvidia is already not improving performance in GTX700 series drivers while GTX900 is still getting performance improvements. However 780Ti is still faster card than GTX970.
On the overclocking part. Nearly every GTX970 can be overclocked to 1500MHz on stock cooling regardless if there is 20*C more or less. At the same time every MHz higher is giving these cards less visible performance gain than on GTX700 series simply because stock clock is already much higher.
GTX960 is not bad for a single 1080p display but it's much slower ( 30% or something ) than GTX970/780Ti.
Exactly our point, yep. While the ceiling may/may not be the same on the 970 upon launch, with driver improvements since then and NVIDIA's apparent lack of support for the 780ti, the 970 clearly has a better upside to it for very little cost increase.ive read from several websites while trying to look at other comparisons on the witcher 3 for a gtx 760 and read quite a bit that Nvidia isn't even releasing improvements for the 700 line really at all anymore.
