- May 10, 2002
- AL
Couple of questions regarding what the title says.
Have an Antec 1200 I rescued from a friend. Previously it had a Cooler Master LGA775 watercooling kit installed. RAD mounted behind the rear fans and tubes going through the pre cut holes on the back of the 1200.
But anyways the question: I would like to mount an H100 radiator on the top of the case. Does anyone have any experience with the h100 and external mounting? How is tube length and routing?
Second question: I would have to drill new holes on top of the case. I'd like it to have a nice fit and finish. What I'm seeing in my head is some kind of rubber piece to fit inside the new holes much like the factory holes on the rear of the case. Question is where do I find a simile rubber seal?
Tips and answers appreciated!
~FA
~FA
