- Sep 24, 2012
So basically I am trying to add another rad into my equation, or maybe just replace the fans on my current setup.
Build thread : http://www.overclockers.com/forums/showthread.php?t=738058
I have done some upgrades since the loop pictured, but nothing to affect the overall heat too much.
Anyways, I now have a GTX780 ACX, (not water cooling this)
Corsair HX750 and different ram as well, so a bit more on the power demand. But overall internal temps have stayed about the same at about 24/25c.
So just the 4770k, but my idle temps are about ~35c and game load is about ~60c, full stress in AIDA64 is about ~75-80c @ 4.4/5 with 1.275v
I was stupid and should have probably bought a 120.3 instead of the 120.2 like I did in the first place but am not sure on if I should just try to add a 120.3 now and rid the 120.2 or add a 140.1 in place of the 140mm case fan in their now. My drive bays are full, the pump is probably staying where it is in the pics, the reservoir location I like so I am limited I know.
Now, I am using the BitFenix Spectre Pro 120's, and there is only two of them on the bottom of the rad pushing up, (nothing on top)
Also not much case ventilation either, only fan is the 140mm on the back of the case, so I have a lot of road options to take and not sure which one to tackle first.
Any input would be appreciated, I'm just sitting at work brainstorming all of this and can't figure out which path to take and the more I think, the more I've been wanting to make a thread.
Cheers,
-Luke
Cheers,
-Luke
