- Nov 10, 2012
- Ankeny Iowa
You should be able to mount the spectra fans uptop right to the rad
You will like th NB's
It should be m3x30mm unless you use fan grills
Make sure you don't puncture a tube with a screw.
These rads have screw protection plates
The rads I seen with them
The screws that come with the E loops are m3 screws
I used the nuts that come with them for washers/spacers and it makes them 30mm long
That should give you nice temps and be quiet
I will recommend two more things. Distilled + silver and Primochill Advanced tubing. Color of your choice. If you do consider than you need to do a full tear down and rinse everything down from the liquid you used prior.
I am tearing everything down, except I already ordered a silver plug (for rad) and ordered masterkleer tubing 1/2 x 3/4, as I have heard primochill is full of plasticizer lately... I've heard a lot of positive remarks on the Masterkleer so I went that route... I am running distilled + silver, but I am going to run Mayhem's pastel white... I've done a lot of research and haven't ever heard anything bad about Mayhem's pastel series..... If stuff begins to gunk, I'll simply run plain distilled.
I am upping to 1/2 3/4 from my old 3/8 stuff, that was way too thin for my liking.
Thanks for the tips though
