rocketcity
- Aug 29, 2012
- Oklahoma
This is my first post, so "Hello to All!"
Carbon Fiber & to a greater extent Carbon\Carbon are used in many applications where it is necessary to dissipate huge amounts of heat. I used to build & fly high power rockets & noticed that while heating one side of a Carbon Fiber fin with a heat gun, the other side of the fin cooled to almost room temps as soon as the heat gun was removed. Formula 1 cars use it for their brake rotors & pads, as well as the now defunct Space Shuttle used it on the leading edges of the wings, etc. It is not the cheapest material on the planet for sure, but we are talking about a water block, not a house, so the price of it shouldn't be completely over the top. I have looked around & have not seen anything about them, but just because no one has tried something should not be a reason to never try it. Unfortunately I developed a severe allergy to the epoxy that one would use to bind it & can not be around the stuff (uncured epoxy) any more, unless I am ready to have my last BSOD. Thanks in advance for your opinions/ideas.
