- Jun 6, 2013
- Thread Starter
- #41
What load program were you running? Well it looks like it is a Hot Haswell. Are all your push pins in tight? can you move the intel cooler with your hands? Did you use the TIM That came with the heat sink.
72C at stock was the H100i, looks like it was working well.
If the cooler is on correctly and the temp is 90c you will need a better cooler if you want lower temps with that CPU.
I have not seen a stock Haswell in the forms with a stock cooler exept for you.
I just realized I had forgot to put the top fan on my case, probably being the cause for the 90C. I just put the fan back on, and so far it seems while running Prime95 I hit high 70's and low 80's as a max temperature. I had applied some Coolermaster "High Performance" thermal paste, it's not anything near top of the line, but I was hoping it would at least be slightly better than the stock stuff. I can wiggle the stock heatsink around, it's not loose but it's not very snug tight either, I'd just say it's in place! Currently I'm pretty disappointed with Intel in the whole Haswell idea. Does anyone know if the next generation of Intel's processor's will support current Z87 motherboards? I've read online that Intel is keeping the current socket type for the next generation as well. I might have to consider delidding my processor to get a good temperature even at stock speeds as currently this seems outrageously horrible. One more thing, what do you mean by are all my push pins tight?
