- Dec 27, 2008
Hi, I'm having trouble finding drivers for my older video card (Asus EAH4870) that are compatible with Windows 10.
I have a new Dell monitor (S2721HS) and it has a 1" border on the screen.
I've read that I need to go into Catalyst and set the scaling(?) to zero, but I don't have Catalyst and have been unable to find a version that will work.
I have tried several versions (found on the AMD website) for legacy cards like mine, but they do not work, when I launch the program, it says nothing to adjust?
Second issue: I can't get into my motherboards bios. (Gigabyte Z170X-Gaming 7)
Tried rapidly pressing Escape or Delete on start up (Megatrends screen flash) but no luck.
Any advice or suggestions would be appreciated.
Thanks!
Thanks!
