- Apr 21, 2001
- Las Vegas, NV
Thanks Sentential.
I know its a coincidence but I'm actually using a DIR-655 for my cable connection. Thus far, I thought I had a pretty good router but you've proven me wrong! The router that I'm having issues with and the reason why I started this thread is a DIR-625.
Is the router you've been meaning to check out happen to be the Asus RT-N56U? I googled DIR-655 unresponsive WAN port and most of the first page results were about that particular Asus router.
I'm going to be stubborn and try setting up my DIR-625 as a WAP one more time. When I plug in the ethernet cable directly into my computer I get assigned an IP of 172.16.2.xxx with the xxx usually being a lower number. Does that mean I can assign the router an IP of something like 172.16.2.222? When I disabled DHCP before I assigned the router an IP of 172.16.254.xxx so I'm wondering if this could be part of the reason why I can't get consistency.
In the meantime, I'll definitely check out www.smallnetbuilder.com.
Thanks again.
If you disable DHCP and use the LAN (NOT wan ports!) on the router to connect to the building's network, the IP you set doesn't necessarily matter aside from it needs to be different from anything else on the network (otherwise you end up with ip address conflicts). If using the LAN ports as described the IP address you assign to the router is only for management purposes, so you could leave it at 192.168.1.1 or some other random address and when you need to configure it conenct via a wire you just manually set the computer's IP to match that subnet/range. This is so you can temporarily make your changes, then revert the computer's ip settings when done. Once a router is setup you should rarely need to access it administratively, so having an out of range IP address and having to manually configure the PC's network settings is only a minor inconvenience.
Without knowing what your building's policies are for dhcp leases and dhcp scopes (IP address ranges) I think it would be safer to just set the router's IP to something random outside of the building's scope and configure the computer manually when you need to manage it.
Make sure to secure your router with a unique admin password.
