- Jan 18, 2012
Your options in the U.S. are channels 1, 6, 11. All others will cross talk and have problems. I suggest trying channel 11 and if that does not work try 6.
Your router should have Ethernet ports. On one of your devices turn off wireless and connect to a physical Ethernet port. How does the connection work? At this point lets not worry about your buildings router, just yours. For the time being lets assume the building is set up correctly and they are just serving you a DHCP address. BTW, what address is that?
You configured your router as a WAP, that's kind of wide open to interpretation. That just means wireless access point. Is it configured as a router or as a bridge?
You have three sections on your router that need configured:
1. Wan side, connects to your building's network. (What address is your building giving you)
2. LAN side, this is what your devices connect to. (You can't use the same subnet here as your building assuming you have your router configured as a router)
3. Wireless, you configure SSID, channels, and security here.
