- Jul 15, 2008
- Suffield, Connecticut
Here's the issue (I think). I've been using the system in my signature for about a month now, minus the 3570k, which I installed 5 days ago. I'm having strange issues with system stability all around.
Issue #1 - Video
I'm using two HD7770s in Crossfire with CCC 12.4, and every time I open a game in Steam and then try to set the proper resolution, and sometimes even when the game is just starting up (this is just after game installation, without any previous in-game graphic setup) the monitor will turn black, audio will stutter, and eventually the PC will turn off. I have had ONE singular instance where I've been able to get passed the loading screen and actually start a game. This issue happens with every game I've tried, not just one. I'm wondering if I should try older driver versions? Both of the GPUs show up in Device manager and CCC, and seem to be working fine.
Issue #2 - Audio
In addition to the two GPUs, I also have an ASUS Xonar DX sound card, with the latest drivers installed. For whatever reason, it does not play nice with CCC 12.4. I have my 1st GPU connected to my monitor via HDMI, and so CCC tries to output audio to my monitor through HDMI. I've tried uninstalling the AMD HDMI audio driver, and it seems to work sorta, but once in a while audio just doesn't work at all, or it switches from my speakers (connected to the DX) and then starts playing through the monitor. I did not have this issue with CCC 12.2. Even when I try to disable HDMI audio and set the DX Speakers as default, CCC manages to switch it back to HDMI.
Ultimately, I'm wondering, should I try reverting to CCC 12.2? I can't find a download for it. AMD only lists the most recent drivers.
Thanks in advance.
Issue #1 - Video
Issue #2 - Audio
Thanks in advance.
