- Jan 4, 2012
- bristol,Va
- Thread Starter
- #21
thats what kind it is. Samsung. Witch used to be really good..
OK.. i just switched out power cables on it.. and i don't really hear no more clicking.. Does that mean that might have been the issue?? And can i repair the bad sectors?? Or move them to a separate partition? or is still jacked up?
I wish I could. Where it's a gateway OEM. They want cover it.. Witch is bull crap.. Not to much I can do.. It's still under warranty to.. ! I'm not the original owner o the gateway.
It is worth a shot, but they will record what drives are in Gateway machines. I've seen screenshots where it says it is an OEM drive and refuses to put in a RMA.
1-3 clicks at spinup after being idle for some time would be normal. I would say that being its a USB enclosure, its most likely a "Green" drive inside, which normally will spin down after anywhere from 30s to a minute of being idle.
