- Dec 31, 2006
- Randolph, MA
This is a serious question guys, and I need help from anyone who is able.
---> Here's the problem:
I use DISKEEPER to defrag my HDD's. It is a FABULOUS program. One of the best I've ever bought. For the past 5 months or so, I haven't been having any problems with my PC, so I've gotten kind of LAX in my scanning/defragging habits. So, in DISKEEPER, there is a Volume Map section, which is color coded. It shows you the HDD in sections of Horizontal bars stacked on top of each other. The colors are as follows:
-BLUE: high performing files & folders
-PINK: low performing system files
-WHITE w/GREEN STRIPES: reserved system space
-RED: low performing files & folders
-PLAIN WHITE: unused space
So, my problem is with the system files (PINK). Those are XP files, and all other related system files in XP. Because I've been so lax, these files have become significantly FRAGMENTED...and I mean BAD.
I don't want to reinstall XP, that is last resort right now (cause I got lots of valuable data store on my HDD that I can't burn off or transfer atm).
Now, there is an option in DISKEEPER, to do a BOOT-TIME defrag. This is the only known way of defragging the system files -- before XP boots. But its very risky, and you can lose files or have to reinstall XP if it makes a mistake, which RARELY happens, so I'm not worried 'bout it.
My question: How can I get all these system files defragmented, when DISKEEPER isn't doing it right?
I know there is built in Windows Defrag, but that is not even near as comprehensive as DISKEEPER, nor as efficient.
So what do I do? I'm at a loss here, because I've run the BOOT-TIME defrag like 10 times in a row, and it just won't defrag all the system files. I mean it might move a few, but there's still thousands that need to be moved, and it's not doing it. It just flies through a few defrag steps, and then starts XP again. :
Please, if anyone knowledgable 'bout PC's or HDD's has ANY suggestions or help, post a reply.
Thanks, FLASH.
Thanks, FLASH.
