I have two maxtor 7200RPMS both are running extremely hot. I've never really relised that HDD ran so hot but these suckers are burning! I belive they are contributing to most of my case temp if not all. What is the best way to cool these bad boys down?
i recommend putting an exhaust fan in the front of ur case right on top of them. i've done this with great success. my 2hdds used to run at 46C now their running at 29C max.
If possible make sure you have a bit of room in between the harddrives for good ventalation. Yeah get a few small fans blowing over them and you should be fine.
All these guys are right. I never sandwich my drives...there lies the way of HD deth!
I often mount them with adapters in the upper bays...I high...1 lo
that way they have room to "breath"
I also have considerable case overpressue so I installed a Front Bezel vent and turned the fans around...I would guess there is 20cfm flow around the HD and out the front and the HD is cool to the touch.
I have seen watercooling but that is a bit extreme for my tastes.
A top mounted HD fan is next to useless...the fans are puny (IMO) and it wont work if youre sandwiched (no room)
If ya got no way of adding a fan to blow over those hard drives... Then maybe a new case will have to do.
Check these babies out.. I got one of these in silver. Anyways.. head to the link and scroll down the page where they show pics of the insides... There you will see the Hard drive bays that have a fan mounted in front of each of the 2 bays. That way the cool air from the outside will blow right across... They use 80MM fans.
nothing better than lots of air!! slap a nice 80mm fan right in front of them blowing out of the case.
this will not only keep the hdd cooler it will blow the heat out of the case.
I have the GlobalWinn I Storm II hard drive cooler and it cools both of my Maxtor D740X drives great. You don't have to any modding and it only takse a 5 1/2 bay. http://www.inflowdirect.com/globisii.html
