- Jul 22, 2005
Run with your case open and a room fan blowing in. If you run ok, then your problem is case air flow.
The temperature diodes are for throttling the cpu to keep it from overheating. They report temperature difference from tjmax, not absolute temperature. Intel won't say what tjmax is and many have guessed that's because it's not necessarily the same for a complete run of a chip -- temperate programs guess at it based on info that's available. BUT, you want to make sure that temp difference is >30c normal; >20c linpak (extreme cpu stability testing).
I'd grab a copy of speedfan and record the temperatures during your gaming. It can be configured to save them in a .csv file that can be opened in your favorite text editor or spreadsheet. The files are saved in speed fan's program folder (C:\Program Files\SpeedFan). Time's in seconds since midnight. You can see exactly what your temps are when things are slowing down. You can see what speed fan's assuming for tjmax and see how close to temperature throttling you are. You can also see voltages if you set them to be saved -- maybe you're having power supply problems...
Edit: tjmax is the temperature at which the CPU starts to throttle -- to keep from overheating.
