If your allen heads get a little worn and the driver just turns in the socket there's a trick you may be able to use. This works if the socket is not totally fubar, get a tube of valve grinding compound from a auto parts store. Put a dap on vg compound in the allen socket, insert the allen wrench, you may get lucky. If the vg compound fails, try epoxy, insert the allen wrench in wet epoxy and let it cure, then try turning the screw. JB Weld is good for this.
Make sure the tip of the wrench is not worn, pretty common with these tiny wrenches.
Another trick is to apply heat to the screw with the tip of a soldering iron, not melting solder hot but close to it.
EZ outs are miss named, they should be called hard outs.
If the above fails then musicfans dremel trick would be the next step.
