- Jul 1, 2006
- Canton, CT
This thread was just created to sum up all the mods ive done on my heatsink and show how much you can improve your cooling for a low cost.
1. Lap the CPU (mine was very concave)
2. Lap the Heatsink (stock had no finish and also was not flat)
3. Better thermal paste (went from as5 to Zalman Super thernal grease)
4. New, tighter mounting system
5. Add a larger fan (double of what stock fan could do at full speed)
Here was my original review of my new freezer 7 pro.
http://www.ocforums.com/showthread.php?t=479358
At that time, I was running at 3ghz, but when I put it up to 3.4ghz at 1.45voltage, the temps would reach almost 64c, and that was only orthos...If I used TAT, it would blow up lol.
Then I started a project where I would lap the heatsink and the cpu. I would also switch from as5 to the new zalman thermal grease.
http://www.ocforums.com/showthread.php?t=480214
That mod gave me a huge improvment of almost 8c. My load temps were now at 56-57c.
Then, because of all the work I had done on the heatsink, I was constantly mounting and remounting it. I relalized that the mounting system was no good and I had to make something tighter. Also, I had a fan that pushed out 90cfm (double the 45cfm speed of stock fan) laying around, so I decided to slap that beast on as well
Here are some pix
I used some rubber washers under the mobo and rubber spacers that came with my asus vento used to mount the hdd's.
I made sure to put plenty of the zalman grease to ensure that every part of both cpu and heatsink would have good contact, and if it was too much, it would spread out by itself.
ALL DONE MOUNTING, I gave it a nice & tight fit.
I couldnt find any more rubber bands and didnt have time to fabricate some better method of mounting the fan, So for now, only one rubber band is holding the fan in place.
This little modification dropped my temps a further 2c, my 3.4ghz conroe loads at 54c.
All in all, the temps were dropped by about 10c. WOW, thats a huge improvment from before when I was worried about overheating.
edit: in all my excitment, I forgot to plug my video card fan in. Lucky for me, its a v1 ultra and it can run passive just fine when its idle. Since its right next to the cpu heatsink, once I turned that on, it was sucking even more air out of it, and lowered the load temps to 52-53c.
Here are some pix
