- Dec 14, 2010
So, during a storm earlier today I decided to break down and tear my PC apart to to replace the stock cooler with a higher-end aftermarket model.
After spending an hour or so taking it apart, cleaning everything up, and affixing the necessary LGA775 mounting bracket I come to find out that my chosen new heatsink (which is massive by the way) hits the fan on my NB cooler (and I think "well, that's a drag, but I'll try it without the fan"), no such luck, I removed the fan and then it was hitting my NB's heatsink itself. Made of Copper, weighs 125g without the fan attached.
So, then I try my secondary option, thinking if the NB cooler and the CPU cooler are made by the same company odds are good they'll both fit next to each other. Wrong! The fit with these two was even worse. Made of Aluminum, weighs 60g.
Okay, plan C, rip apart my socket 939 rig to scavenge the NB HSF from it. I was hoping to avoid this, but having no other heatsinks on hand good enough to do the job I figured I may as well try it. Wouldn't you know, this one fits perfectly. Made of Copper, weighs 55g with the fan attached.
This is why I don't like mATX boards, or mATX/mini tower cases for that matter, they aren't easy to work with/in and difficult to get things to fit properly. I have to say, had this been a regular ATX board I doubt I would have had any of these problems. Really wish I could have kept the heatsink I had originally put on there, seems like such a drag to go from 125g of Copper to just 55g of Copper.
Well, after a three-hour process to replace a CPU HSF and a NB HSF (though I had never intended to do so) I finally have everything back in the case and got it up and running again.
At least I didn't have to take the board out. Everything I read on this HSF before purchasing it swore up and down that the board would have to be removed to install the heatsink. Ha, not in my case!
Results are encouraging, with CPU socket temps down from the low-to-mid thirties down to the high twenties/low thirties in degees Celsius. Idle temps in RealTemp are about the same really at 28-32°C most of the time; temps at typical loads during average use are around 33-40°C (haven't tried full load on prime or any benchmarks yet). While temps are about the same I say this is encouraging because the fan on this heatsink is spinning at 900-1000RPM, while the stock one had to spin at 1100-1400 all the time to maintain the same temperatures.
Out with the old:
After the upgrade:
That darn capacitor being right there at the top-left makes mounting a NB HS a more difficult task than it should be.
Out with the old:
After the upgrade:
