- Jun 22, 2002
- Macomb Twp, Michigan
nikhsub1 said:As I said at procooling, you would be better served with those pumps in SERIES rather than parallel. You are getting no more flow than 1 pump with them in parallel. Parallel adds no pressure, your block is restrictive and choking the parallel pumps, meaning they are doing no good. Series is redundant as well but works far better if one pump should fail.
Ok i see how parallel is but how do you setup the pumps in series? Is it just:
Rez-pump-pump-rad-block-block?
