hi I need some help to get my fx8350 going a little stronger .
of course first my p.c specs are as follows
990fx extreme4 asrock mobo
8350fx amd cpu
antec 650 earthwats psu
8gb 4x2 umax 1600 ram
scythe kabuto air cooler
sapphire radeon hd 6950 2gb model with unlocked shaders
creative sound blaster z
crucial m-4 120 gb ssd
seagate 1.5 tb storage
plus fans controlers etc.
antec 300 case .a little old school but easy to mod.
My query here is that i cant seem to get a good overclock tried using the amd vision control but only able to reach 4.6 ghz and nothing would run ,heaven benchmarks etc. prime 95 was no problem and heat didnt seem too bad ,windows 7 aero got all messed up tho and only returned to normal when brought back to stock 4ghz .the included asrock axtu program was terible as well uping the multiplier didnt show on cpuid and constantly came up as not rerspondng. soo into the bios we go turn off all energy saving stuff and crank up the multiplier ,no bsod but not booting properly and same bios says 4.5ghz cpuid says 4.2 .why?? and does anyone have a set of bios settings that will help me get closer to 4.8 or 4.9 .Impossible on air cooler ?? should I get a closed loop water cooler ?? will all this improve gaming fps ,which is descent so far I would have to say above 40 on all games .14000 geek bench score and 1430 or so with heaven dx11 moderate settings . I think i should be able to push more out of this machine .No problem to buy water cooler just need some good advice .
8350fx amd cpu
