Hi,
My goal is to make the pc around $600-700 while making sure the components don't bottleneck each other like the gpu and the cpu or vice versa.
I do understand that getting a dual core will bottleneck some of the components, but I really need the dual core and instead some of you may know a better item to get for the value since some of the parts may not even be used to there fullest potential.
Please don't advise me to get a quad core I already have one I need this computer to test some things ^_^
Also if you can please tell me if this pc is compatible or not, I've checked over the internet and it should be fine, but still I'm skeptical.
Also, even though I'm getting the Amd II X2 processor I may get the Amd Athlon 64 x2 6400+(3.2 GHz) as well and I'm wondering if it's compatible with the entire pc?
When making suggestions on my build please provide the name of the item as well as a link that follows it to a site where the item can be purchased.
Budget: ~$600.00 -700
I'm over my budget by like $400-500 can someone please help. This is my first time building a custom computer and hand picking parts from so much variety.
Case: NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
http://www.newegg.com/Product/Produc...82E16811146067
$124.99
Processor: AMD Athlon II X2 270 Regor 3.4GHz Socket AM3 65W Dual-Core Desktop Processor
http://www.newegg.ca/Product/Product...82E16819103873
$79.99
Motherboard: GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.ca/Product/Product...82E16813128519
$94.99
Power supply: OCZ ZT Series 750W Fully-Modular
http://www.newegg.com/Product/Produc..._-YT17-341-052
$11
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Produc...D=6ryyw0dra9tv
$44
Graphics Card: EVGA SuperClocked 02G-P3-1469-KR GeForce GTX 560 (Fermi) 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Produc...scrollFullInfo
$234.00
Hard drives: Western Digital Caviar 1.5 TB
http://www.newegg.com/Product/Produc...82E16822136793
$200
CD Drives: LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Produc...82E16827106289
$22.00 x 2 = $44
CPU Fans/Case Fans/Heat sinks:
XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU (Heat sink & Cpu fan)
http://www.newegg.com/Product/Produc...82E16835233081
$29.00
XIGMATEK LED Fan Crystal series CLF-F2005 200mm
2x200mm purple led fans = $20x2=$40
http://www.newegg.com/Product/Produc...82E16835233079
1x140mm Yate Loon(blue led) fan = $11.00
1x120mm Yate Loon(blue led) fan = $11.99
OS: Windows XP Service Pack 3
Networking: TRENDnet TEG-PCITXR Gigabit Network Adapter 10/ 100/ 1000Mbps PCI 1 x RJ45
http://www.newegg.com/Product/Produc...82E16833156139
$13
By the way the objective of this computer is to play old games and utilize both cores to the best of there potential or for what they are worth at least.
Total so far: ~$1007.00
$124.99
$79.99
$94.99
$11
$44
$234.00
$200
$22.00 x 2 = $44
$29.00
$13
