- Apr 21, 2001
- The North Pole
Yo all,
recieved the last and most important part of my system two days ago: a brand new AYHJA 1333. I was offered an 1400, but the extra $60 seemed like a waste.
System specs:
[unorder=circle]
[#]Asus A7V133 rev. 1.05
[#]AMD Athlon 1333@1333 AYHJA
[#]NCP 256 Mb PC133 cas2(running in cas3)
[#]Inno3D GeForce2 MX400 64 Mb
[#]SB 128
[#]2 x Samsung Spinpoint V11+ 30.6 Gb(RAID 0)
[#]Netgear FA310TX
[#]Actima 52x
[#]Case Aopen HQ08 w/ Aopen FSB-300 power supply.
[#]Cooling: Papst 0.9 W intake fan, 2x Papst 0.6 W exhaust, Alpha FC-PAL35U(modified) w/ Y.S.tech 1.44 W, ThermalTake memory + VGA heatsinks, Original fans VGA-CPU + chipset + power suplly. 7 fans in total.
[/unorder]
PROBLEM is: Hangs during installation!. Cpu temp is about 54 degrees Celcius(idle or little load), case temp about 30 degrees. Default voltage: 1,7 volt and 10x133. I could propably lower the case temperatur if I changed to runded cables, draft is propably somewhat reduced due to cable jam.
I´ve used only the Windows drivers, no extra multimedia players etc. Always hangs in installation, ends up with that I can´t even boot(hangs while loading Windows). Sometimes I manage to almost get a full install, but not without 3-5 hangups and fail-safe mode recovery.
It´s like this: I install the drivers for some unit(not the same every time), upon restart it will not boot. I delete the drivers during fail-safe mode, and install them again. After doing this a few times, it ends up booting in windows, locks up and there is a continous high-frequenzy beep from the speakers.
I´ve re-formatted the harddrives at least five times and increased the CPU core voltage, but it still ends up the same.
What is wrong?!?!?
regards,
Henry.
System specs:
[unorder=circle]
[#]SB 128
[#]Netgear FA310TX
[#]Actima 52x
[/unorder]
What is wrong?!?!?
regards,
Henry.
