Ok, first i need to get this out of my system: $%**%$%**%$(&%(^(#^*)%($$(&!@!@#@%%^@^#$%$#$
now that's settled......I just picked up a MSI K7 master (MS-6341) which uses the AMD 761 chipset, an AMD athlon 1.333 266 fsb, 256 mb DDR ram, and a bunch of other stuff that's unimportant now.
Here are the problems i'm running into -
#1 - Bios is incorrectly identifying the athlon as a amd athlon 1.0 ghz.
#2 - Bios is incorrectly identifying a Western Digital 40 g HD as a 35 g HD.
#3 and most importantly, I CAN'T GET INTO THE BIOS!!!!!!!!!!!!!!!!!!!
that's right, ever heard of a problem like that before? During the boot up, i hit del to enter bios, and the damn computer freezes. I USED to be able to get into bios. The mobo has a built in soundcard, which i disabled both in bios and with hardware jumpers, but what I had initially noticed when I connected a SB Live Value, the computer would not let me enter bios, only about 10% of the time i could get in, and it helped if i entered the bios after a soft-reboot. If i took out the SB Live Value, the computer would let me get into the bios. Now, with or without the SB Live in there, whenever i hit del to enter the bios, all i get is a blank screen with a blinking cursor. The 4 LED lights thing does not help, because it just continues to display whatever it was displaying as I hit the del key.
I've tried and successfully re-flashed the bios, jumper-shorted the bios, played with a jumper that's supposed to have something to do with adjusting the CPU bus frequency/multiplier. The computer works perfectly fine, except for the 3 reasons listed.
Anybody else EVER have a problem remotely related to this? I figure the mobo bios functions are just DOA and i gotta replace the mobo. I just would prefer not to as that would require me to drive back to my parents home and take care of it.
Thanks for any help,
