i'm planning on doing this for a 6600 non-gt pci-e card in particular, but i'm after some general cpu-heatsink-on-vga-card advice to get everything straight in my head. this will be a rambling post, here's basically all my thoughts mashed together:
the perfect candidate would be a copper, high-fin-density 80mm-fan heatsink preferably without the retention clip going through the middle. it could be attached either using zip-ties around the card itself, by drilling two holes through the sink to use the large-hole mounting system, or by drilling four holes through the sink to use the smaller-hole mounting system. since i don't have a drill i'd rather the zip-tie option, i'm curious about disadvantages to this - nothing major has popped into my head yet.
i don't drill holes in things very often, i'd like to mount eventually using screws but i'm not sure how to drill precise holes possibly through fins. perhaps high-fin-density means drilling holes isn't an option.
a hunch tells me that the gpu die is taller than the memory, so the heatsink wouldn't make ram contact despite possibly covering the chips. i wonder what kind of spacer material could be used to bridge the gap between memory and heatsink base - anything would be better than a gap of air, right?
these strike me as interesting candidates (once stripped of fans, housing, etc.), i'm just wondering if there's anything obvious i'm missing:
any thoughts, suggestions, flames? it seems many low-profile xeon heatsinks are exactly what i'm after. this one is a cheap monster, but 1 pound might be a bit much, not to mention it might not physically fit on the card.
