- May 15, 2006
Unless you put a rheostat between the source and the fan, yes, it would run full speed. As long as the fan pulls less than 500ma, it would work just fine off a USB connection.I was thinking about something like that, since it's a 5V fan (I did toast the old fan with 12V trying to test it) I was considering tapping into a USB port, but I don't trust myself enough with a soldering iron to do that... Even if I did, I guess that makes the fan run 100% all the time, right? And would I be able to use that USB port anymore?
