- Dec 25, 2004
Ok, I've been banging my head against a wall on this OS install. Mainly because I was using a USB drive for the install ISO, and the board apparently needs the USB 3.0 drivers installed for that to work.
Anyway, I had a burned DVD with the right image on it, so that got me past the previous fail point. Now it isn't even seeing my SSD. I think it is a listed on the compatible list: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147360
It does have a BW at the end of the part number, so I'm not 100% sure. However, when I'm in the BIOS the only SATA drive that shows up in the optical drive.
What am I doing wrong?
I don't see anything that covers this in the FAQ at Gigabyte support.
Thanks!
Thanks!
