- Dec 25, 2004
- Thread Starter
- #21
Ok, hold on a minute here, I'm getting confused.
Currently I am:
A. Using a USB image that has been modified by a Gigabyte program to have USB support for 7 slipstreamed. When I run Win 7 setup from here, the setup doesn't see the Samsung SSD 840 (which is not on the compatible list from Gigabyte). This drive IS PLUGGED INTO A NATIVE INTEL SATA PORT. The manual says Native Intel ports are 0/1/2/3/4/5 and the non-native ones are 6/7. I've only tried 0-5 and none of them show the drive.
B. At the select drive screen in setup, when I click on "Load Driver" it DOES see all the USB ports, and I can plug in a USB stick with the SATA drivers on them and it does see the USB drive and installs the drivers. However, no drive shows up on the select drive screen after it has done this.
C. I was planning on getting a Samsung 850 Evo that IS on the compatible list from Gigabyte. Is this going to make any difference?
(I guess I should have bought that MSI Z170 board when it was offered to me....but no, I wanted the extra PCI-E 16x slot.... )
Currently I am:
