- Jul 12, 2011
- Virginia USA
which one u guys think i should get ?
I am running all 4 dimms can't access the first slot next to cpu socket without removing the heat sink. at least for me. built this before I knew anything about computers
Do you have the pump power to a molex? The pump should run 100% all the time (dont use mobo pins unless you use bios to turn them to 100% all the time)
Though it should be able to keep a SB chip cooler than that at 4.4.. a hyper212+ does a great job, so this should technically beat it!
I use the d14 as well and its mad quiet.. at 100% (my fans are on a standalone conroller) they still arent louder than the scythes I have on my door @ 5v.
Yes, i got the pump power to a molex so it is running 100%. I am almost at the point of thinking that i got a H80 that is not working like it should. But will get two 200mm case fans tomorrow and try and get a better air flow though my case before i throw it out the window
