- May 24, 2005
This was my first build...I have most the wireing coiled in and around the drive bays in front of the PC and a couple few lying on the bottom like some fan connectors and these big thick grey wires with Pink and Green connectors that aren't connected to anything, and to tell you the truth i dont really know what they are for. However there are 0 wires above/over the motherboard or any other device.
I did clean it out some yesterday and moved some wireing around a bit and I am now running it at 2.3ghz and have had 0 problems. problem solved? we'll see.
thx for all the help and I'll cya's around.
Maybe you had a bad connection? Well glad to hear it is sorted out...
