- Jul 10, 2004
- Austin, MN ( we make SPAM here )
Help Improve My Case Cooling! 56k warning
Check my sig for system info. To start off here are some pics-
its actually an M1a not an H1a
My heatsink is a vantec aeroflow but as you can see in the pics i took off the 70mm TMD fan because the noise got annoying and i replaced it with an 80mm Panaflo H1B.
Currently with all fans turned to full except the 120mm (at 7v), I'm running folding@home 24/7 and my temps(celcius) are as follows:
MBM: CPU=46 Case=34 Sensor 3=38
but Hmonitor gives me different...
Hmonitor: CPU1=34 CPU2=38 Mainboard=46
If my CPU really is at 34-38 then I'm pretty happy but I'm doing worse-case-scenario and going with MBM readings.
I'll be having some spending money coming in pretty soon (about $40-$50) and I want to get the biggest improvement out of my money. I bought my first dremel last week so any mods that require one are now do-able. A few things I'm considering getting:
1. New fans for the window: a 92mm to replace the old 80mm I took from the PSU that is currently lining up with the CPU fan. And second for the window I want to replace the stock raidmax (even though it is pretty ) I want fans that aren't very loud, say under 35db, but i do have a rheobus so if somthing pushes a lot of air at 7v then it might work too.
2. New fan for CPU or new heatsink altogether? My adapter is pretty ghetto but it does seem to be working fairly well with an 80mm Panaflo H1B. The question is whether or not the aeroflow heatsink is very effective at all if its not using the TMD fan. I dont particularly wanna sell me aeroflow on ebay and have to take a loss on it but the 70mm fan was annoying with the vibration and all. Is there somthing i could do to the regular aeroflow heatsink and/or fan to reduce the vibration? Should i just stick with my current adapter and just buy a better fan for it? any recommendations on that?
3. New PSU? People say raidmax PSUs that come included with their cases are cheap. Mine is 420w and as we speak it is giving me the following:
12v = 11.84-11.90v
5v= 4.94-4.97v
core = 1.68-1.7v
I/O= 3.38-3.41v
Aux= 1.52v
How are those?
Everyone seem to love the Fortron PSUs and if I could find one with enough juice to power everything I have now and give me headroom for the future I'd really have to consider it. Buying a new PSU would also allow me to take my other Panaflo L1A out of mine and put it on the window, possibly eliminating the need for buying 2 new fans. I do want a PSU that is quieter than my raidmax though.
A few notes about my case: I know it is a cord jungle right now , Im waiting to get my final fan setup decided and installed and then ill clean it all up which should also help temps a little. As the pic asks, should I cut the front plastic off of my case to allow for better airflow for the 120mm intake? I already cut out the metal grill that was right next to the fan but I dont know if the plastic needs to go also.
Thats it for now. Please post any advice you have for me
12v = 11.84-11.90v
5v= 4.94-4.97v
core = 1.68-1.7v
I/O= 3.38-3.41v
Aux= 1.52v
How are those?
